I added an RT5047 (power supply for LNB) to V2 minitiouneV2 ,
with the Tutioune software, the switching works perfectly, but with Ryde the power supply is on permanently, and it is impossible to switch it.
Someone would have already had the problem ?
Regards and 73's Patrice F1NSU
Ryde LNB Power Supply
Re: Ryde LNB Power Supply
After a double check, the LNB's switching works.
But, in all case the LNB's power is on during the boot, and it switch off after the message "longmynd not load " appears.
Is it possible to improve it ?
Regards
Patrice F1NSU
Regards
Patrice F1NSU
If longmynd not loaded appears. The connection between Ryde and minitiouner is lost..
Explain me how Ryde should controll the monitiouner without connection... ..
Best regards Benno
Best regards Benno
