Ryde LNB Power Supply
Patrice
Post by Patrice » Thu Aug 26, 2021 3:11 pm
I added an RT5047 (power supply for LNB) to V2 minitiouneV2 ,
with the Tutioune software, the switching works perfectly, but with Ryde the power supply is on permanently, and it is impossible to switch it.
Someone would have already had the problem ?
Regards and 73's Patrice F1NSU
Patrice
Re: Ryde LNB Power Supply
Post by Patrice » Sat Aug 28, 2021 7:31 am
After a double check, the LNB's switching works.
But, in all case the LNB's power is on during the boot, and it switch off after the message "longmynd not load " appears.
Is it possible to improve it ?
Regards
Patrice F1NSU
Pa3fbx
Post by Pa3fbx » Fri Nov 05, 2021 1:16 pm
If longmynd not loaded appears. The connection between Ryde and minitiouner is lost..
Explain me how Ryde should controll the monitiouner without connection... ..
Best regards Benno
