Hi Folks
I tried my Ryde with Knucker for the first time tonight
I checked the output of Portsdowns/Pluto with Portsdown/Knucker first on 437T 333B/W, all good, picture fine
Using Ryde all I got was "Locked No Video", good S/N and SQI
When I coughed I got the shock of my life the monitor coughed back, so the audio is fine
Should I have used H.262 maybe
Is there still problems getting DVB-T working or is it just me
Something to do with VLC maybe
Anyway the project looks like it's moving in the right direction and well done to all the contributors!
Cheers Roger VK5YYY
Progress Knucker -> Ryde?
Re: Progress Knucker -> Ryde?
Hello I am in the process of putting the ryde receiver into service on the table, everything is going well in DVBS with the minitioune, on the other hand with the Knucker in DVBT, only the audio works or the image is passed !!
I can see the picture on the portsdown
can someone tell me where is my mistake
thank you for your reply
Witch output of the hdmi did you use?
DVBT only works on hdmi 0 (closest to the power plug)
benno
benno
Hello
The HDMI connector near the rp4 power supply does not work!
Under linux the command gpio read 7 gives 0 instead of 1
Can't find the error on my side
With portsdown no problem to have the mage
73 F5AOD Philippe
73 F5AOD Philippe
