Ryde has lost HDMI output?
After working well for a fortnight my Ryde has stopped outputting HDMI.
I have rebuilt the SD card, and tested the monitor lead on a different RPI.
I've tried choosing the 'debugging' mode from the SSH menu. Still nothing.
Running the diagnostics produced the following:
pi@raspberrypi:~ $ menu
device_name=DEL-DELL_P2419HC
state 0xa [HDMI CUSTOM RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
pygame 1.9.4.post1
Hello from the pygame community. https://www.pygame.org/contribute.html
(1920, 1080)
(1, 1)
23.43843916003259
no surface
no layer
Press enter to continue
So to my untrained eye it 'looks like' its seeing the monitor (a Dell as shown).
Any suggestions?? Any way I can get the RPI to use the second HDMI port or has something in driver silicon expired??
Thanks for any pointers....
pygame 1.9.4.post1
(1920, 1080)
(1, 1)
23.43843916003259
no surface
no layer
Re: Ryde has lost HDMI output?
Hi Gareth
Worry not. I think I know the cause and will fix it later this afternoon. A software configuration control issue.
Watching with interest as mine worked great for two days, I gave up trying all settings and used the composite o/p.
Steve
Steve
Gareth and Steve (and anyone else with this problem)
Please could you reselect the full HDMI display, reboot, log into the console, and then enter:
Do you get a picture (internet connection required)? You can press ctrl-c to ext
If that does not work, try a "Development" update (press d at the y/n update prompt) and repeat, please.
And tell me what happens as I can't reproduce the problem.
stop
vlc rtmp://rtmp.batc.org.uk/live/gb3hvIf that does not work, try a "Development" update (press d at the y/n update prompt) and repeat, please.
Hi Dave, Development upgrade did not fix it so I ran the command you provided after exiting to Linux from the Ryde SSH menu - I assume that's right.
pi@raspberrypi:~ $ vlc rtmp://rtmp.batc.org.uk/live/gb3hv
VLC media player 3.0.12 Vetinari (revision 3.0.12-1-0-gd147bb5e7e)
[00a25ca8] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
[00a5d478] main interface error: no suitable interface module
[009c6b58] main libvlc error: interface "globalhotkeys,none" initialization failed
[009c6b58] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[00a5d478] skins2 interface error: cannot initialize OSFactory
[00a5d478] [cli] lua interface: Listening on host "*console".
Command Line Interface initialized. Type `help' for help.
> [abce1610] mmal_codec decoder: VCSM init succeeded: CMA
[abce1610] main decoder error: buffer deadlock prevented
[a984f9d8] gles2 generic error: parent window not available
[a984f2c8] mmal_xsplitter vout display error: Failed to open Xsplitter:opengles2 module
[a984f9d8] xcb generic error: window not available
[a984f2c8] mmal_xsplitter vout display error: Failed to open Xsplitter:xcb_x11 module
Which looks like all sorts is wrong.....
Hi Gareth
That looks exactly right. I should have asked the $64000 question - was there a picture on the HDMI display?
Nope, nothing. Just listening to the beacon (no picture) having rebooted everything and checked with a different Ryde.
Rerun test - same message, no picture.
For a sanity check (i.e. could the HDMI on board have failed) shall I try a Portsdown card??
Beacon was down this afternoon
Hi Gareth,
Just to clarify, by no picture do you mean one of ryde's red messages saying no video do you get nothing at all i.e. a blank screen?
If you get a blank screen do you get anything while the pi is starting up?
Tim
Tim
Clarification - beacon was received early evening but audio only.
No picture or screen image of ANYTHING, not even during boot sequence. No 'red screen', no picture, nothing.
This behaviour is what prompted me to consider a hardware fault. I'm using a short, cheap uHDMI to HDMI extension which was my immediate suspect but this has been tested fine on another Ryde/RPi4.
I wasn't aware the RPi4 had any settings it could 'save in flash' (except to the uSDcard) so I'm beginning to think this is hardware failure?
Its a bit strange......
