password root
DL5BCA
password root
Post by DL5BCA » Wed Aug 26, 2020 7:17 pm
I wanted to make changes (indenting the left edge of the screen on the analog Pal output) to the boot / config.txt. Since I am not allowed to do this as a pi user, I entered a password for the user root ...
Now I wanted to register with it, which unfortunately doesn't work.
Why does this not work?
I always have crazy ideas.
Please don't be surprised.
Re: password root
Post by g0mjw » Wed Aug 26, 2020 7:36 pm
You need to use sudo, not the root login
e.g. sudo nano
don't do things as root as it will probably result in files with ownership you can't change unless you do something like
sudo chown pi [filename]
or whatever the syntax is.
DL5BCA
Re: password root
Post by DL5BCA » Wed Aug 26, 2020 7:58 pm
Hallo Mike,
thank you, that works...
