Ryde in Gb3EY faulty?
G3GJA
Re: Ryde in GB3EY faulty?
Post by G3GJA » Sun Dec 18, 2022 9:18 pm
Hi Philippe
The 0 on GPIO red 7 indicates that the tuner has not locked to the incoming signal.
Things to check:
  • Make sure you have selected the right input socket (A or B)
  • Has the pre-set in use been configured to work with the symbol rate you are sending to the Ryde?
  • Does the screen display the red background with black text "Not Locked"?
Clive G3GJA
Philippe
Re: Ryde in Gb3EY faulty?
Post by Philippe » Mon Dec 19, 2022 10:54 am
Hi Clive
thank you for your reply
It is the A socket of the tuner that is used
Symbol rate send to Ryde ok
The screen is black and the text in white and the sound and ok see photo of the monitor screen in HDMI
I do not know what to do !
Reception Ryde.png (550.29 KiB) Viewed 13093 times
Post by G8GKQ » Mon Dec 19, 2022 1:47 pm
Philippe
You are using the "Interim" receiver, not the final version.
The final version of the Ryde DVB-T receiver is integrated with Ryde. So if you go into the Ryde on-screen menu, and then scroll through the presets, you will find some DVB-T presets. You can adjust those using the remote control, or amend them (use a text editor on the file ryde/config,yaml).
The interim receiver does not activate the GPIO line. The final version should do.
G3GJA
Post by G3GJA » Mon Dec 19, 2022 4:06 pm
Ignore what I said Philippe. I misunderstood what you were asking. I thought you were referring to DBV-S
Clive
Philippe
Post by Philippe » Mon Dec 19, 2022 4:51 pm
what do we edit in the config.yaml ?
Philippe
Post by Philippe » Wed Dec 21, 2022 6:44 am
Hi Dave
What should I modify in the config.yaml file to have the image instead of having a black screen with the indications in white??
I find it weird that no one has the same problem as me.
73 Philippe F5AOD
Post by g8gtz » Wed Dec 21, 2022 9:26 am
Phillipe,
Have you updated to the Ryde latest firmware - you need to do this if you want any support at all...
If not you cannot change the screen colours.
Post by G8GKQ » Wed Dec 21, 2022 9:50 am
Philippe
If you want to modify the config.yaml file, the items that you need to modify are further down, so use the "page down" key to see them.
Your big problem is that you are using the ssh menu to control the Ryde, not a Remote Control and the on-screen (HDMI output) menu. For proper DVB-T operation, you need to select a DVB-T preset from the on-screen menu, just like you would select a DVB-S/S2 preset. Scroll through all the presets (slowly)and you will see what I mean.
