Ryde Minor Software Update 202011160
Post by G8GKQ » Wed Nov 18, 2020 10:19 pm
I have just released a Ryde software update that corrects the handling of LNB frequency calculations for C-Band LNBs (as used for 3.4 GHz reception). It also adds 4 new remote controls, and has a tidier SSH Console Menu.
This is a minor update, and if your Ryde is working correctly for you, there is no point in updating.
In other news, I have updated the Wiki https://wiki.batc.org.uk/Ryde_Receiver to include reference to possible RF interference from the Raspberry Pi 4 HDMI cables, and also the need to shut down the Ryde correctly, rather than just cutting the power.
Thanks to the 4 contributors of the new Remote Control Codes for doing the Beta testing, and of course to Tim MW0RUD for the frequency calculation bugfix.
Re: Ryde Minor Software Update 202011160
Post by g0mjw » Thu Nov 19, 2020 7:42 am
On the shutdown correctly point, regrettably the mains supply here is particularly unreliable. Is there anything that can be done to make unexpected shutdowns as safe as possible - e.g. disabling write caching? Also can we initiate shut down with a remote control button?
g8lce
Post by g8lce » Thu Nov 19, 2020 9:28 am
From my testing of the Ryde and disconnecting the power causing problems, I found that a reboot from ssh into the Ryde menu cured the problems so a powerloss detection and reboot would work. Maybe an external powerloss detection circuit and a GPIO pin that causes a reboot? This could also act as a watchdog reboot with an external detector being kept off by another GPIO pin 'ticking'.
There is already a remote control button and GPIO pin for shutdown. See https://wiki.batc.org.uk/Ryde_GPIO_Connections
