Charity test equipment disposal
g4bao
Post by g4bao » Thu Sep 16, 2021 4:44 pm
Andy Wade G4AJW is disposing of surplus test equipment to raise money for Charity
You can download the latest list of test equipment (Excel file) from the link below
http://g4bao.com/Downloads/Andy-test-eq ... nload.xlsx
Download the latest version above before phoning, it will be updated as the equipment sells
Contact, Pickup etc.
All communication should be via John G3UUT g3uut@qsl.net.
Do not reply on the reflector or any other email address as it will not be dealt with
All equipment must be collected from North Cambridge.
Other collection methods may be possible by arrangement if they involve a minimum of additional effort. Many other items such as adapters, connectors, modules, coax, other cable etc. will be available to those collecting at least one item of equipment.
Please note that the table contains the following definitions of condition and associated caveats.
Working
Most of this equipment was functional until recently and has been stored in a dry warm environment all its life. The equipment status should be taken as not working, for parts only and no liability is accepted as to its condition or safety. However, some equipment has been powered up recently and quick tests have been done (basically power on/off, display light up etc) but a Y in this column should not be relied on. If you need further information, please contact G3UUT. If the working state of the equipment is really important to you, please check it first as donations cannot be returned.
Donation
These guide prices are assuming that the equipment is for amateur use only. If commercial use is envisaged, then a bigger donation would be appropriate.
All proceeds will go to the National Brain Appeal* and will be allocated to the Rare Dementias support centre appeal.
*National Brain Appeal Registered Charity No. 290173. A limited company registered in England. No. 01844281. https://www.nationalbrainappeal.org/
Donations should be made to Andy Wade's JustGiving Page
http://www.justgiving.com/fundraising/Andywade-g4ajw
Please phone or email to check the item is still available before you donate or travel as donations are not returnable.
