Shack Tidy Up Items for sale
Items for sale here please
G4ZCN
Post by G4ZCN » Sun Feb 02, 2020 5:14 pm
I have the following no longer required items for sale;
1 x 13cm small 11 element commercial Yagi antenna c/w N type connector. £10.00
1 x Used Stratex Band Pass Filter 2300Mhz SMA connections £30
1 x new boxed HIDES BU500 TX up converter for Es Hail Sat. £100
BU500 high power.jpg (356.45 KiB) Viewed 494 times
Lot of 3 home brew pre amplifiers for 6m,2m & 70cm with controller & cables. All in working condition. £75
Lot of 4 x Military spec.N type to N type plug hard line patch links, excellent quality, various lengths 20-30cm. £22.50
1 x New RS packaged SMA to waveguide transition (10Ghz WG) £35
1 x new Bert Modderman PE1RKI slotted vertical antenna 14dbi gain suit repeater (approx 150cm long) for 3.4Ghz. £100
1 x Used KUHNE S-Band GaAsFet PA KU PA 3240 TX 3200-4000Mhz, complete with large heatsink removed from unused surplus equipment £85
1 x Stella Doradus 3.4Ghz 8dB commercial vertical antenna (approx 60cm long). £35
2 x New TOHTSU CX600N coaxial RF relay £75 each
1 x Used Microwave Associates SMA RF relay 12GHZ 15vdc £60 a pair or £35 each
1 x Used DOWKEY 401-420832A 12vdc SMA RF relay with logic connections £35
1 x 5.7Ghz 8dB gain commercial vertical antenna (approx 35cm long) £25
1 x Boxed unused KUHNE MKU CXN 57 TX (23cm up to 6cm) Frequency Multiplier £100
Pictures of all of the above items available via email or whatsapp. Postage within UK at cost
Just added
Shireen PLO 3300 Phase Locked Oscillator Signal source, +15dbm RF power output. £50
Shireen PLO 5500 Phase Locked Oscillator Signal source, +15dbm RF power output. £50
Link to Shireen website for data:
https://www.shireeninc.com/osc/rf-produ ... r-plo-3300
Contact Barry, G4ZCN via PM or call/txt on 07957163136
Barry
G4ZCN
E: b.grylls@ntlworld.com
Return to “For Sale”
