Peculiarites when using Pluto GPO0 for keying
Posted: Wed Dec 13, 2023 3:01 pm
Gents,
I have just finalised Langstone V2 transceiver with a Pluto, consisting of a "Control Unit" housing the Raspi, Pluto and support circuits and band specific "Frontends" housing PA, RX/TX relay, LNA and RX filter.
Pluto is version C/D with external OCXO. SW is F5OEO version 0303 (like my Pluto version B used for DATV on QO-100). Th C/D specific patch from F5UII is implemented. I use the Pluto GPO0 for keying the TX and I have implemented the "GPO0 disable" circuit using GPO1 to prevent keying durin Pluto calibration.
In the ongoing "Set to Work" process I have noticed two peculiarities:
1. During start-up, in the very last seconds of the "Loading" screen, GPO0 goes high and consequently keys the TX, but there is NO RF. When the "Loading" screen disappears after a couple of seconds, GPO0 goes low and the Langstone is ready for operation.
2. If one during receive presses "SET", chooses "TX att" and adjust the TX level using the scroll wheel, GPO0 goes high and keys the TX. As above there is NO RF output an the Pluto is still in receive mode, howver with antenna disconnected ude to the TX/RX relay is in TX position. GPO0 stays on until one presses "PTT". Then RF comes on and ona can press "PTT" once more and everything is back to normal.
Nono of the peculiarites are critical, but nevertheless I wonder if others have experienced same or similar phenomenons.
vy 73
Jorgen, OZ7TA
vy 73
Jorgen, OZ7TA
