Langstone V2 Update
Posted: Sat Oct 21, 2023 2:16 pm
I have just released a small update to the Langstone V2 code.
The changes are as follows...
Fixed a bug at first start-up after booting where the settings were not always being applied correctly. You may now see a new Red message 'Waiting for Lang_TRX.py" for a few seconds on start-up. This is normal and does not indicate a problem.
Squelch is now available for all modes.
The squelch now uses the S-Meter level as the trigger.
The current Squelch setting is displayed as a thin bar above the S-Meter. If the S-Meter reading is below the Squelch level then the audio will be muted.
For modes where you do not want to use squelch just leave it set at zero. Separate squelch settings are stored for each mode and band.
