Possible issue with multiplying transverters
oe6rke
Post by oe6rke » Mon Jul 17, 2023 6:30 pm
Hi All,
playing with oe8fnk Freds hydra (multiplyer) up/down to 10GHz i found a possible issue at https://github.com/g4eml/Langstone-V2/b ... UI_Pluto.c at line 2775.
Original (Pluto will freak out if the qrg is 10 Gigs hi):
frTx=fr+bandTxOffset[band];
if(frTx > maxHwFreq)
frTx = maxHwFreq;
if(frTx < minHwFreq)
frTx = minHwFreq;
My fix for this is a clause to care the right mode to set it:
if(bandTxHarmonic[band] ==0) {
frTx = maxHwFreq;
frTx = minHwFreq;
hope this is helpful to other folks using this multiplyer transverter,
br Robert, 73 de oe6rke
Re: Possible issue with multiplying transverters
Post by g4eml » Tue Jul 18, 2023 10:36 am
Well spotted, that error seems to have crept into the Langstone V2 code. All of the testing with multipliers was done using V1.
However you should really be using
if(bandTxHarmonic[band] < 2)
because the default setting for the harmonic number is 1 not 0. Your change is always bypassing the error checking.
A similar change also needs to be added to the Rx frequency setting and the Lime version.
I have made these correction to the github source.
Colin G4EML
