error on Langstone
g4eml
Re: error on Langstone
Post by g4eml » Mon Apr 29, 2024 8:15 am
You could also try just reinstalling GNU Radio
sudo apt-get -y install gnuradio
And make sure it completes without errors.
G0ILO
Post by G0ILO » Mon Apr 29, 2024 6:30 pm
Hi Colin,
I went for an install, no longer get the error message, but it jut sits on the 'Langstone Transceiver' screen. Oh and now I've a red LED active in the USB audio interface which I didn't have before so I guess that's functioning. In the log I get this host error. I'm afraid the Raspberry Pi environment is totally alien to me....
Cheers,
Paul.
g4eml
Post by g4eml » Mon Apr 29, 2024 10:53 pm
That is saying it can't find the Pluto device.
The default setting assumes the Pluto is called pluto.local and is at 192.168.2.1
Either the Pluto is not working correctly or it has the wrong name.
If you have changed the Pluto name or IP address then you will need to set it using the set_pluto command.
If the Pluto has the default settings then you could try connecting it to a different USB port.
Also the power supply voltage can be critical. The Pluto doesn't seem to like anything above 5V.
G0ILO
Post by G0ILO » Tue Apr 30, 2024 7:12 am
Okay Colin that gives me a few things to try later.
This Pluto I've previously used on the Satsagen spectrum analyser project and also with an SDR app or two so I could've changed something but I can't remember at the moment. I do have another Pluto to try if things get desperate. That other is untouched, not even carried out the frequency extension mod yet.
Regarding the power supply the whole set-up is running on the official Raspberry Pi PSU but I've no problem supplying something else if required.
Many thanks,
Paul G0ILO.
Post by radiogareth » Tue Apr 30, 2024 7:46 am
From my experiences with my PD4/Langstone setup I frequently had issues with Langstone not finding the Pluto. I added a low-drop 1A Schottky diode in the +ve supply rail wire in the Pluto lead and the problem went away. RPi is running happily at 5.2/5.25V and the Pluto gets about 4.85V.
Even on the PC, where the USB is perhaps a tad under 5V, the Pluto remains happy.
G0ILO
Post by G0ILO » Mon May 06, 2024 10:24 am
Thanks for the input chaps.
I've had COVID so only just picked this up again. Anyway, tried second Pluto, Schottky diode in Pluto positive rail, different power supply, fresh install using a new SD card but still no cigar.
I do now get this in the log rather than 'cannot find host' or similar.
G0ILO
Post by G0ILO » Mon May 06, 2024 10:32 am
Actually above was on my second Pluto. Attached is my original one and the log I'm receiving now.
g4eml
Post by g4eml » Mon May 06, 2024 8:00 pm
Those errors are still saying it cannot see the Pluto.
You could try the following.
Log in using SSH and try pinging the Pluto to check it is responding.
ping 192.168.2.1
You should see multiple 64 byte messages confirming the connection.
If that fails then check the configuration of the Pluto
sudo mount /dev/sda1 /mnt
more /mnt/config.txt
This should show the Pluto config file.
In the [NETWORK] section it should read
hostname = pluto
ipaddr = 192.168.2.1
ipaddr_host = 192.168.2.10
netmask = 255.255.255.0
G0ILO
Post by G0ILO » Tue May 07, 2024 5:51 pm
Hi Colin,
Just done as you suggested and I'm assuming all is correct?
G0ILO
Post by G0ILO » Tue May 07, 2024 7:13 pm
I did go for another install but took the option to select the hardware just to see what gives
opening screen
After selecting Pluto
After 10 seconds or so back to this screen
Then it'll go all screwy if I select Pluto again.
