error on Langstone
error on Langstone
From today the Langstone doesn't want to hear of working.
I also tried to reinstall it and update the firmware, but nothing changes.
Tried with other Pluto too!
Error message says:
<Lang_TRX_Pluto.py failed to load see/tmp/LannstoneTRX_Pluto.log>
Error message says:
Re: error on Langstone
What does the log file say?
Also check your sound device. If it is not working it will cause this.
You need to connect to the Langstone as you did when you installed it and enter
more /tmp/LangstoneTRX_Pluto.log
Colin.
Colin.
I have the same problem here. From the log file I think it is a sound card problem. I have used two different sound devices and with Pluto and Lime so far, but no solution. Which sound card is proved to work?
73 Gerhard OE3GBB
73 Gerhard OE3GBB
- Screen Shot 04-24-24 at 02.27 PM.PNG (32.9 KiB) Viewed 537 times
Looks like the wrong sound device being used? Are you using the specified dongle? See the Wiki.
./set_sound did it! Thanks so much. 73 Gerhard
