Accessory pcb
Posted: Thu Jul 30, 2020 5:41 am
Hello all, from across the pond.
I want to let you know of an experimental pcb I made. This is a first version and will no doubt be upgraded later.
A wideband Rx Preamp and low power Tx PA for UHF, with T/R switch. This can be built for wide coverage or for a specific band.
I consider this an adjunct to the Langstone Project: https://wiki.microwavers.org.uk/Langsto ... sion_Forum This is my first of likely many iterations which will improve the utility of the ADALM Pluto.
From the Antenna, there is a simple mechanical Tx/Rx relay. On Rx, there is a low noise amplifier using a Qorvo SPF5189Z which is a rather good device. On Tx, there is a GALI-74+ which provides about +25db of gain. There is provision for another gain stage using a MOSFET AFT05M (there is a family). The low power device is in a SOT-89. The schematic is a direct copy from the AFT05M evaluation board.
My plan is to have a single BPF on the Antenna side, which will have 2 characteristics: low insertion loss (for NF) and deep stop bands to suppress TV stations. This filter will also serve to suppress the Tx harmonics. This filter is in the early stages of development. (as of summer 2020). Don't hold your breath waiting for it.
ALWAYS OPEN TO COMMENTS OR SUGGESTIONS! Look me up W0IY on QRZ
I've just received first boards and will be delayed several weeks by an important activity. If there is interest,I'll mail 2 pcb to the UK for anyone that will really put them to use. Share with a buddy. would prefer to make just 1 shipment.
