Using RP2040-zero as mouse
Post by g8gtz » Tue Feb 18, 2025 12:11 pm
I thought I'd trying using the RP2040-zero as the mouse on my new Langstone build.
Got the code loaded as per Github but can't find the connection details - only the Arduino schematic is on the wiki:
https://wiki.microwavers.org.uk/File:Lmouse.JPG
Is it published somewhere or am I just missing it?
Re: Using RP2040-zero as mouse
Post by radiogareth » Tue Feb 18, 2025 1:39 pm
If this doesn't help its ask Colin direct :-)
https://github.com/g4eml/Langstone-Mous ... ematic.pdf
Have to say I was wondering the same thing as they are a lot cheaper than the Arduino part....
Post by g0mjw » Tue Feb 18, 2025 1:46 pm
Sledgehammer and nut comes to mind. Surely the PI could control this by itself with a little GPIO sacrifice? I wonder how hard it would be to update the code for a rotary encoder and couple of buttons? Could we use the SR select pins, these are not used in Langstone as far as I know and probably not often in the Portsdown.
g4eml
Post by g4eml » Tue Feb 18, 2025 3:09 pm
Noel,
The connection diagram is valid for either board type. The IO pin numbers are the same for both boards.
Mike,
In theory it could be done using the Pi GPIO. However my experience is that rotary encoders can be tricky to get working reliably in Linux. Interrupts can be delayed by other system activity and steps end up getting lost. Leaving that task for the mouse to handle was the simplest solution.
Post by g8gtz » Tue Feb 18, 2025 5:16 pm
Thanks - I'll update the image on the wiki with the one from github (which I didn't look at!!)
