Langstone Discussion Forum
I have had great results from old Hands-free car phone mics, the earlier models in a 'clip onto your sun visor' black plastic box, about 1.5" square. They do need a 5V ghost feed though, which means they don't work with the Portsdown/Langstone Dongle which only has around 3 volts on the mic. Should be easy enough to add another DC blocking cap and take a genuine 5V off the USB dongle feed.
Another option might be a 'modern' speech processor, in the mid-2000's I built a little SM kit that fitted into the hand mic on my FT817. It certainly works, but makes the speech very 'breathy' according to reports. CHip is probably obsolete now and I can't find the kit info. Another option might be the SOTA speech compressor, not tried, but there are lots of reviews on the www.
Hello
I am building the Langstone transciver and i like to use a high resolution rotary encoder can any one tell what type and how i can connected as i was readying on the langstone page and i saw the diagram for PC mose connection but i think the high resolution rotary encoder is defferent...
Many thanks
73's Joe 9H1GT
Many thanks
73's Joe 9H1GT
Hi Joe,
I used one of these devices: https://www.ebay.co.uk/itm/116233030561 ... BMjqOGj_Jk
It is solidly made with a good bearing and an optical detector. The only downside is that it is larger than the square click encoders. It has a built in 5 Volt 3 terminal regulator so it will not run from a 5Volt supply (probably needs 8V min). However, it is an easy matter to get inside to bypass the regulator. Whilst you are inside, check the wiring colours rather than rely on the seller's description!
This works very well with the little Arduino board specified by Colin.
73, Russ, G4SAQ
73, Russ, G4SAQ
Hi Russ
Many thanks for the information i will search for it on the ebay and buy one...
73's
Joe 9H1GT
73's
Joe 9H1GT
I also use the same type of encoder as Russ. I bought the 400 pulse per revolution version.
I agree that you need to open it up and bypass the voltage regulator so that it will work directly from 5V.
It works well with my Langstone mouse design on GitHub.
https://github.com/g4eml/Langstone-Mouse
Or this one from Amazon works well from a 5v supply: https://amzn.eu/d/g8fF3Ga
Use the 5v version of the Arduino to match it.
Clive G3GJA
Clive G3GJA
I think they are all the same type. The advert says 5 to 24V but when you look inside there is a 7805 regulator. In theory this needs at least 8V input to regulate correctly.
Hello Dave
I don't know if you can help me but i am building the Langstone transciever and i like to you please can i buy a ready programed SD card for it as i'm not too good on programing were i have to copy and paste the files..
Many thanks
Joe 9H1GT
Many thanks
Joe 9H1GT
The Portsdown 4 SD card includes the Langstone, I think it is available from the shop, or download an image.
Hi Mike
Thank you for your reply,yes i have the portsdown 4 working fine but i like to have the Langstone SD ready programed for it only just to boot the Langstone when switch on..but i am not very good to copy the software..
many thanks
Joe 9H1GT
many thanks
Joe 9H1GT
