I saw Colin updated the Github today with waterfall so tried installing and it doesn't show on my Rev A. but everything else works. tx rx freq change etc.
Also the the con-fig file wont accept Lan settings? (edit save eject)
I now have Lan working with a network adapter with the small otg on it. On a Rev B Pluto.
The waterfall also is working on this revision.
Ill have to update the firmware on the Rev A and try again.
The otg to Ethernet adapter that worked is Branded "Plug able" fast Ethernet (small black plastic case no USB hub) Borrowed from GB3KM new build
Thanks help Terry
