GB3PV Activity
Re: GB3PV Activity
Another good repeater looking for users.
John G4BAO and friends have upgraded this repeater with a Ryde input. Now fully digital the access range has increased where I can access it from my QTH in Bedfordshire at 52km. G4HJW, G4BAO, G4CPE and M0SKM can be found on there at various times. There's no stream as yet but I believe there are plans to provide one in time. If anyone wants to test access I can provide a temporary stream.
Steve
Steve
Re: GB3PV Activity
Hi SteveM0SKM wrote: ↑Fri Oct 22, 2021 1:31 pmAnother good repeater looking for users.
Steve
I didn’t realise it was back on …
According to Cambridge repeater group it’s off air
Will have a look for it …can hear and get into GB3PS FM a repeater if I put the 23cms beam vertical so some sort of path that way from east Essex
https://cambridgerepeaters.net/
Regards
Steve
Steve G4HTZ
Great Wakering Essex JO01JN60PC qth 4m asl
70cms DATV portsdown 4 + RYDE rx …18element yagi at 15m
Re: GB3PV Activity
Hi Steve,
Output is 1316MHz as before, symbol rate 1M/s, DVBS-2.
Input from 333 to 2M/s Ryde will search.
Let me know how you get on, best signal is evenings after dark.
I have used GB3PS but only from Dunstable Downs, I can hear it from home but no access.
Steve
Steve
Re: GB3PV Activity
Ok thanks for informationM0SKM wrote: ↑Sun Oct 24, 2021 10:46 amHi Steve,
Steve
Got a 36ele beam on 23cms can put the pre amp at mast head for rx testing …no relays yet …also got a ryde …been changing shack round so may be a few days before I can look for it
Regards
Steve
Steve G4HTZ
Re: GB3PV Activity
Not quite right - Ryde will only scan preset SR, not the full range....Input from 333 to 2M/s Ryde will search.
Re: GB3PV Activity
GB3PV will decode 333/500/1M/s and 2M/s.
73 Steve
73 Steve
Re: GB3PV Activity
John G4BAO visited the site this morning and has cured the receiver fault, so GB3PV should be working again. Please try it and post reports here!
Re: GB3PV Activity
Hi all,
I'm still a little suspicious that the 5V supply to the RX is low as it shows the"flash" in the top right of the screen. This could well have been the root cause of the issue as it was stuck, mid reboot. (it's bewyound my comprehension why the Raspi should have been designed to need well over 5V to work reliably!)
I'm suspicious it could be the cable/plug/socket from the PSU rack to the RX that's a bit dodgy causing volt drop under some conditions . Turning the volts up is a SMD soldering iron job in the SMPSU, not doable on site, so I'm going to leave it alone for now, as it's working.
If anyone would like to try a QSO email me (john@g4bao.com).
Don't ask here as I don't check in very often. Until I work out how to make the forum "push" messages at me it'll stay that way as life's too short to check in ever day and see if there's anything interesting!
John
John
Re: GB3PV Activity
Dave,
Good reception here in IO91RV; MER 11.2 at present.
G4CPE monitored while I put a signal in and it was stable with no sign of the PSU problem. It would be real handy if PV was streamed.
73 Steve
Re: GB3PV Activity
Thanks for the report Steve.
I now have an RSS feed in to firefox from this forum so should be looking at it more often!
John
John
