Sat.Tracker
Posted: Fri Jul 26, 2024 1:34 am
by SkyVision
Hi John
That Sat.Tracker thingo on X you posted
Could you put a link up and a couple of photos please
So we can see your secret sauce, what's in the box and where to find the plans
Or is it a bought module you've hacked together
Cheers Roger VK5YYY
Re: Sat.Tracker
Posted: Fri Jul 26, 2024 7:36 am
by M0SKM
Don't know what you saw but I had to reply.
This is the device I use, it only works with ICOM radio's at the moment, It's the best radio kit I've bought. Will be ideal for tracking the ISS.
Mine came directly from the US (support is brilliant), you can buy them from MLS now.
http://www.igatemini.com/sat
Steve
Re: Sat.Tracker
Posted: Fri Jul 26, 2024 8:34 am
I guess it's ready made but the cost of not DIY is very high.
There is a software alternative available from AMSAT
https://amsat-uk.org/beginners/satellite-tracking/ e.g. SatPC32 and also Gpredict.
The Rotator interface is trivial to make using an Arduino and K3NG's firmware.
https://github.com/k3ng/k3ng_rotator_controller. An Arduino or perhaps better a Raspberry PI can do all of this. Apologies this link is from 2012,
https://amsat-uk.org/2012/06/07/raspber ... -software/
Kevlar at the ready - Portsdown...
Re: Sat.Tracker
Posted: Fri Jul 26, 2024 1:50 pm
by G7JTT
Hi Roger and all the main unit is a camera pan & tilt unit that works on 24v and has internal multi turn pots for feed back. The oringal project can be found here
https://www.hackster.io/viorelracovitea ... are-48f9cd
I use Orbitron to track sats with the DDE plugin from here
http://tripsintech.com/orbitron-dde-azi ... to-serial/
Apart from the pan & tilt unit (which I had for years) I think I built the whole thing for well under £50. It does work well but has limitations, like it's only 0' to 90' elevation which means it needs to spin 180' azimuth when it passes the 90' but the P&T unit is fast enough.
Hope this is of help it really is a simple project compared to some of the other controllers out there.
73 John G7JTT
Re: Sat.Tracker
Posted: Fri Jul 26, 2024 2:32 pm
by SkyVision
Thanks John
I saw that one Steve and Mikes K3NG one looks similar
But your one appealed to me because of the manual adjustments
I've just realised my huge Pan Tilt unit is 24Vac which throws a spanner in the works
viorelracoviteanu says his does AC so that might work
Or I'll have to investigate a low cost low voltage AC motor drive
Will read up on it and watch the Youtube vids
Can you confirm John if you are using just relay output or control like a H brigde
Steve your one looks like relay output is that correct?
Cheers Roger VK5YYY
Re: Sat.Tracker
Posted: Fri Jul 26, 2024 3:19 pm
by G7JTT
Hi Roger yes just relays with the MOSFET modules as well so the Arduino can produce a PWM exactly as per the drawing. I've also got a 24v AC and 240v AC units but neither had the pots inside to give position.
73 John
Re: Sat.Tracker
Posted: Fri Jul 26, 2024 4:05 pm
by M0SKM
Yes relay to Yaesu spec with cable supplied, it also has PstRotator output which I use with my Spid rotator.
It was the brilliant doppler tracking that caught my eye.
- 20240726_170947.jpg (112.23 KiB) Viewed 11967 times
- 20240726_170934.jpg (113.86 KiB) Viewed 11967 times
Re: Sat.Tracker
Posted: Fri Jul 26, 2024 5:38 pm
by G8IKP
I've done a similar thing to Mikes suggesion, an Arduino Nano, 3 transistors, 3 resistors and K3NG's code with GPredict. Total cost less than a fiver. GPredict also does rig control and all the doppler shift.
It was a no brainer for me, all in the full amateur radio spirit
John G8IKP
Re: Sat.Tracker
Posted: Sat Jul 27, 2024 8:11 am
I forgot to mention the more complex beam controller / tracker developed by John Drew, VK5DJ
https://www.vk5dj.com/beam.html
This is a stand alone unit with many options. Not sure if it is still available. If so it is local to Roger - local being relative, at least the same continent.
