Dexing Encoder Modulator
SkyVision
Post by SkyVision » Thu Jan 11, 2024 2:28 am
Hi Folks
Dexing have some interesting new products with HEVC/H265
Here is their new professional DVB-S/S2/SX unit which goes down to 0.5Msym
https://english.dsdvb.com/news.php?modu ... =94&id=585
Guessing it is around 1500-2000 pounds
We have Dexing DVB-T modulator at our repeater VK5RDC here and we can web into it and change settings
Input switching via DTMF to HDMI switch which is simple and effective
Dexing professional products have high MER and the video encoding is pretty fluid, maybe not as good/economical as NVidia
Wide range of inputs types available, it does take a bit over a minute to boot up
I've been buying Dexing for work and importing it for a while, they seem pretty easy to deal with
We are using mainly Dexing DVB-T domestic modulators upconverted to 23cm here, because it's cheap and works well
(Yes, I know that is of little interest to you Brits and Europeans), still plenty of spare spectrum here for the moment
Cheers Roger VK5YYY
Re: Dexing Encoder Modulator
Post by g8gtz » Thu Jan 11, 2024 9:32 am
Roger - what was agreed at WRC affects everyone including VK land - the clue is in the "W" which stands for World! It does depend on what your regulator decides to implement but you could end up with restrictions across the whole of the band, including 1296MHz.
For the record, the UK has significantly more "spare" spectrum on 23cms than anywhere else as our band goes up to 1325 MHz :-)
