Adding 18v to the Minitiouner, help!
Posted: Mon Mar 09, 2026 11:23 pm
Hi all
Minitiouner v2
I have a buck converter to drop the 12v down to 5v to drive a relay (one of the Arduino ones).
I have a boost converter to increase the 12v to 18v for the LNB.
I have a relay (mentioned above).
The relay side of it:
+5v from buck converter to DC+ of relay coil
gnd to DC- of relay coil
IN1 (trigger) comes from where on the minitiouner?
+18v from boost converter to COM of relay
N/O goes to where on the minitiouner?
Basically, I need to know the 2 pins:
LNB vertical signal pin
LNB point to feed +18v
Studying the schematic and the FTS-4335 I believe that LNB_A1 (J4 pin 1) for Antenna A and LNB_A2 (J3 pin 1) for Antenna B are where the +18v should be injected to select vertical polarisation but I do not want to fry anything.
Which pin (or pins, there are 2 antenna ports) is the one the software turns on when you choose vertical polarisation?
Massive thanks for the help in advance
de M0ODZ
Greg - who is ---> this close <--- to completion
Minitiouner v2
de M0ODZ
