MiniTiouner V2 - second TS NIM not detected
Posted: Mon Feb 05, 2024 6:47 pm
Hello all,
I have extended my Minitiouner V2 with the circuit board for the second TS. I have successfully programmed the FT2232 module according to the instructions in the BATC Wiki. Unfortunately, I get the error message "NIM not detected, we quit" when I start the MiniTioune V1.0.1.0r beta software. When testing the second channel I get the following messages from "TestMyMiniTiouner_V1_3b":
DLL version: 3.2.16
we have found 2 device(s)
device 0:
device named: USB <-> NIM tuner A
For I2C, we will use this device
FT2232H I2C is open
Handle: 7305392
device 1:
device named: USB <-> NIM tuner B
For TS, we will use this device
FT2232H FIFO open for TS
Handle: 7276056
FT2232H FIFO closed for TS
USB driver version: 2.12.36
------ IP and UDP detection ------
IP n° 1 = 192.168.2.16
UDP address : 127.0.0.1 port : 1234 using IP interface : 127.0.0.1
****************** I2C controller INIT *******************
I2C controller INIT OK
OK MPSSE is empty
Init MPSSE I2C done!
NIM Test
Trying to get the Demodulator serial number
ERROR: impossible to read a correct value from Demod chip
END Test NIM
I soldered in the additional 10k resistor, but that didn't work either. I checked all the soldering points, connections, voltages, etc. Everything was ok.
Do any of you have a solution to my problem?
Greetings from Upper Franconia
Thomas - DL6RCG - JO60BA
DLL version: 3.2.16
device 0:
FT2232H I2C is open
Handle: 7305392
device 1:
Handle: 7276056
OK MPSSE is empty
NIM Test
END Test NIM
