SR/freq presets..help needed
moonbouncer
Post by moonbouncer » Sun Oct 15, 2023 12:50 pm
Hi all,
I have a Minitiouner FTS-4334L with v0.8 software running here. It's works fine.
There are 5 preset knobs in the upper left panel for SR and frequencies.
I want to use more preset knobs, so I added knobs 6,7 and 8 in the config file. But without result ;-)
I don't get an error message, but the program simply won't show more knobs.
I see pictures on the internet from other hams who use up to 10 preset knobs. So I assume that what I want is possible.
Does anyone know what might be the problem?
73's de Ruud PA7RP
Re: SR/freq presets..help needed
Post by G3GJA » Sun Oct 15, 2023 2:26 pm
Ruud
The version you are using is limited to 5 buttons on each side.
Upgrade to v0.9 or v1.01 and then you will get 8 on each side.
It is not possible to change the number of pre-sets in any version; it's hard coded.
Clive
