ELAD DATV RX available at WIMO
Posted: Mon Jan 16, 2023 7:16 pm
by G4HTZ
I have noticed WIMO in Germany are stocking a DATV DVBS/S2 receiver as a ready built unit from ELAD …you need the minitoune download still .
Link here for interest
https://www.wimo.com/en/pf-rxsat?queryI ... n_products
Re: ELAD DATV RX available at WIMO
Posted: Tue Jan 17, 2023 9:41 am
Before ordering, I know someone who bought one and wasn't very happy with it. There were issues with the LNB supply.
Posted: Tue Jan 17, 2023 3:38 pm
by M5TXJ
Hi Mike,
Isn't the issue that the LNB supply is simply the supply voltage that is directly connected to the F socket therefore the RX needs an 18v supply for DATV. Also connecting to terrestrial aerials has the probability of shorting the supply.
73 Dave.
Posted: Wed Feb 14, 2024 3:45 am
by DL9SDL
E-Tiouner from ELAD
I tried to run on the same software V.0.9.9.1.h on which I have running the original minitiouner since years to run a new ELAD e-tiouner. The software on the PC comes up with the same look an feel , but the setting buttons for the power supply of the LNB´s is grey and cannot be set. Even by supplying via a Bias-T with 18V to the LNB, there is no RX-signal coming in. I have issued a claim ticket at WIMO and sent back the ELAD. Response from WIMO: no error found despite I described very detailled the behaviour.
What´s the difference to the former Minitiouner I bought in the DARC shop, which is running well ?
Is there any software patch available which makes running the ELAD ?
Please help, tnx and 73, DL9SDL, Helm
Posted: Wed Feb 14, 2024 8:42 am
by zr6tg
This should in theory work with Open Tuner as well, anybody running this that can test?
Posted: Thu Feb 15, 2024 4:31 pm
by G4KLB
Helm,
I can confirm the ELAD RX does work on Minitioune software with no problems.
The LNB voltage is whatever the supply voltage is, there is no other way to control that. Have tested with a bias tee and that works fine on QO100, there must have been a fault on the one you had.
ELAD MT.jpg (409.82 KiB) Viewed 13122 times
Tom
Have tested with open tuner 0.9 and everything works as expected, so no problem there.
Screenshot (85).png (1012.83 KiB) Viewed 13128 times
Posted: Sun Feb 18, 2024 4:12 pm
by g8ayc
The unit appears to be to the BATC V2 design but with the DC-DC convertor and FTDI module laid out onto the main PCB.
If you don't want the power supply voltage appearing on the LNB connectors, there are individual links to disconnect these connections.
It's a nicely made unit if you don't want the hassle of making up something yourself.
Nigel G8AYC.
Posted: Sun Feb 18, 2024 6:40 pm
by g4eml
It now says 'No Longer Available' on the web page. Presumably they have run out of NIMs.
