No NIM Detected
g8pgo
No NIM Detected
Post by g8pgo » Tue Oct 04, 2022 10:58 am
I am having problems getting my MiniTioune working. Running TestMyMiniTioune_V2_3 I get the following output.
Have I got a faulty Tuner (SERIT FTS-4434LV ?
TIA
DLL version: 3.2.16
we have found 2 device(s)
device 0:
device serial N° DA6NQ4W5A
device named: USB <-> NIM tuner A
For I2C, we can use this device
FT2232H NIM_I2C is open
OK, we will use it with Handle: 10339976
device 1:
device serial N° DA6NQ4W5B
device named: USB <-> NIM tuner B
For TS, we can use this device
FT2232H FIFO open for TS2
OK, we will use it with Handle: 10340128
USB driver version: 2.12.36
>>>>>>>>>> NO MiniTiouner-Pro connected to USB AUX! <<<<<<<<<<<
****************** NIM I2C controler INIT *******************
NIM_I2C controler INIT OK
OK MPSSE is empty
Init MPSSE NIM I2C done!
NIM Test
Trying to get the Demodulator serial number
No NIM detected
No NIM detected
ERROR: impossible to read a correct value from Demod chip
END Test NIM
Re: No NIM Detected
Post by G4EWJ » Tue Oct 04, 2022 3:29 pm
Which MiniTiouner hardware do you have?
g8pgo
Re: No NIM Detected
Post by g8pgo » Tue Oct 04, 2022 4:14 pm
V2 Board, FTS-4334 tuner and the other major parts supplied by BATC
M5TXJ
Re: No NIM Detected
Post by M5TXJ » Tue Oct 04, 2022 4:31 pm
Have you fitted the resistor to the FTDI module?
73 Dave
Re: No NIM Detected
Post by G4EWJ » Tue Oct 04, 2022 5:14 pm
I'm using v2.0a of the tester, but even without the resistor, the program does report the decoder chip in the NIM being found at I2C address 0xD2 and then it says "Incompatible hardware".
Check voltages from the regulator.
Your output shows that it's failing when it tries to detect the NIM on the I2C bus. If you have a scope, look at SDA and SCL on J7 near the FT2232H module. This is the I2C bus and you should see some activity when the test runs.
Check the values of R4 and R5 under the FT2232H. These are pullup resistors for the I2C bus.
g8pgo
Re: No NIM Detected
Post by g8pgo » Tue Oct 04, 2022 7:53 pm
Thanks for your help guys
Have found the problem with a very strong magnifying glass.
A very fine whisker of solder between pins 1 & 2 of J7, dragging SCL down to ground.
Re: No NIM Detected
Post by G4EWJ » Tue Oct 04, 2022 11:26 pm
Jolly good.
