MinitTiouner - Lock, but No picture
Posted: Thu Sep 09, 2021 8:56 pm
Just built two MiniTiouners
One is working fine, the other has an issue, On the Portsdown, lock is shown as well as MER etc, but no Programme Name or Picture.
I've carefully buzzed out the PCB TS_2 data lines, all ok but I noticed an error on the circuit diagram: Pin 36 (TS_2 Sync) on the tuner is shown as going to Pin CN-2/17 on the FT2232H module, but it does not, that's the same on both tuners, so the schematic seems to be incorrect.
The Tuner is correctly soldered, so is the FT2232H.
I've substituted the FT2232H with the other tuner and the FT2232H is working correctly.
I'm beginning to suspect a faulty tuner, but before I unsolder this has anyone else any ideas?
PS all voltages are ok, checked before first power!
BR Justin
BR Justin
