RT5047 BATC AddOn Board
OE8JPQ
Post by OE8JPQ » Mon Sep 30, 2019 1:47 pm
I've succesfully bult the RT5047 board and there is one question left:
How do i connect the other RT5047 for the second lnb? I mean +12V/GND/LNB is clear but with VSel and Enable i'm not so shure.
Do i just make a y-connection there or are there some dedicated pins for this?
73's de Phil OE8JPQ
PS: If there are only 5-6V on the output (LNB) the ground connection underneath the IC is not present/faulty . Maybe it is a good idea to add this fact to the wiki. I had the same problem on one side and it took me a while to figure that out :? :D
