Oscar-100 WB Beacon UDP Mode
Posted: Sun May 12, 2019 2:10 pm
Hi Folks
I'm trying to send the video/audio from MiniTioune to my raspberrypi using udp.
For some reason, when using the combination of my raspberrypi with the wb beacon, the video does not come through, only the audio. The video codec is detected correctly though. All other signals seem to come through fine (BBC Arabic, as well as other ham signal from Oscar-100). Additionally, running VLC locally on my Windows PC shows the beacon video.
Has anybody experienced this behavior before? It's as if the WB beacon is using some codec variation that is incompatible with the raspberrypi hardware h264 decoder.
Jonny
Jonny
