MiniTiouner on 13cm
M0DHP
MiniTiouner on 13cm
Post by M0DHP » Wed Oct 25, 2017 12:51 pm
Can a MiniTiouner receive on 2326MHz?
The wiki says that the latest Serit NIM works up to 2450MHz, while the datasheet (https://wiki.batc.tv/File:FTS-4334L_Series_F1.pdf) says the upper limit is 2150MHz. I don't know if 2150MHz is a hard limit (i.e. the NIM can't be programmed to go above that) or a soft one (it will work but with reduced sensitivity).
My first /P trip with the MiniTiouner was unsuccessful - not a hint of carrier from GB3TZ - QTH was Dunstable Downs three miles away. This may well be down to using only a homebrew 10 element Yagi at 2.5m AGL with no preamplifier or BPF, but I would like to eliminate the NIM range before I do more testing.
Thanks and 73
Ray M0DHP
M0SKM
Re: MiniTiouner on 13cm
Post by M0SKM » Wed Oct 25, 2017 6:42 pm
Hi Ray
Both of my Serit MiniTiouners receive GB3TZ direct. I'm about 2.5km from TZ.
Steve
Find me on D Star through GB7BP
M0DHP
Post by M0DHP » Wed Oct 25, 2017 6:54 pm
M0SKM wrote:Both of my Serit MiniTiouners receive GB3TZ direct. I'm about 2.5km from TZ.
Thanks, Steve. What antenna do you use?
M0SKM
Post by M0SKM » Wed Oct 25, 2017 7:31 pm
Currently a Tonna 25 element yagi; relay switched for TX/RX.
Up to the point where my neighbours trees became a problem I was using a Wimo flat panel just outside the shack window; I got good results with it but it needed a small pre-amp.
From the downs you should pick it up on a small antenna fairly easily.
Video PID 32
Audio PID 33
FEC 3/4
Steve
M0DHP
Post by M0DHP » Wed Oct 25, 2017 7:46 pm
That's really useful data, Steve. Many thanks.
F6DZP
Post by F6DZP » Thu Oct 26, 2017 7:57 am
Yes the datasheet says "250MHz up to 2150 MHz", but the NIM_synthesizer can be set from 143.75 MHz up to 2450 MHz.
As you say,
Jean-Pierre F6DZP
