Can anyone point me to where an explanation of minitioune.ini file settings can be found ?
In particular, what is WebMonitoring used for ?
I note that the setting OM_ID must be the same as was used to register on vivadatv.org, but when I registered I used my name (Nick) not my call sign, so my call sign will not tie in with the password on the forum.
Will this be a problem ?
Regards,
Nick - G4NKV.
minitioune.ini settings
Re: minitioune.ini settings
Web monitoring allows others to monitor what you are receiving on the VivaDATV site. You can also set it up to show a new still off the received stream every 3 seconds. Handy for monitoring repeater inputs, for example this one on HV http://www.vivadatv.org/tutioune.php?om ... ation_id=1
You can also see signal strength, MER, bit error rates and the received constellation.
What would really be the icing on the cake would be if you could remotely tune said receiver (if it is on your own stream)
You may be able to go into Viva DATV and change "nick" for your callsign - that seems to be the house style - and makes it consistent across all users.
73. Ian.
73. Ian.
