I've just started to test my Portsdown and Minitiouner running on 146.5MHz and 333kSpS and the decode seems rather slow and blocky to the point of freezing.
Also carrier lock takes an age (sometimes it won't lock at all) , higher symbol rates seem ok and when lock is achieved MER is good.
Hoping to do some OTA tests, but given the bench performance so far I doubtful they would be success.
Maybe it's finger trouble with the MiniTiouner program ?
Any pointers ?
73 Tim
Minitiouner V2 RBW decoding latency ?
Re: Minitiouner V2 RBW decoding latency ?
Hi Tim,
Make sure you select DVB-S rather than Auto - and don't expect 333ks/s to be as good as 4MB/s. Its pretty essential to use H264 and best not to have audio so all the bandwidth is available for video.
Hi Mike,
Many thanks for the tips and making the changes you suggested has helped in terms of signal acquisition but not sure how to turn off the audio - maybe I have to use console mode for that ?
Latency is still about 6 seconds - but not sure what I should expect.
I'll leave it running for a while and see how stable it is.
73 Tim
73 Tim
Hi Tim
If you are using the "Pattern" mode, there is a problem with the software that causes blocks and freezing. Try it in CAMH264 mode. This has no audio, and is the most reliable 333KS mode. The MPEG-2 mode with the camera (selectable from Menu2) is not as good at 333KS, and you can turn off the audio from the console (setup, audio).
