Case for V2 tuner ?
G4WIM
Case for V2 tuner ?
Post by G4WIM » Fri Jun 02, 2017 4:27 pm
Just been assembling my V2 tuner and what a great piece of work it is !
Question,
I see in the wiki it's built into a nice looking case - any idea where I could get one ?
73 Tim
DG8KD
Re: Case for V2 tuner ?
Post by DG8KD » Fri Jun 02, 2017 4:34 pm
as mentioned in the wiki:
(https://wiki.batc.tv/MiniTiouner_hardware_Version_2)
The PCB has been developed to fit snuggly inside a Hammond 1455 series 103x120x53mm enclosure and uses standard leaded components so no specialist techniques needed.
At least available at digikey and on ebay...
Cheers
Rainer
Post by g0mjw » Fri Jun 02, 2017 4:43 pm
Google for 1455N1201
Post by g0mjw » Fri Jun 02, 2017 5:04 pm
g0mjw wrote:Google for 1455N1201
See https://wiki.batc.tv/File:Notes_on_buil ... iouner.pdf in the Wiki, its not that easy to find.
G4WIM
Post by G4WIM » Fri Jun 02, 2017 5:52 pm
doh !
Should have guessed it would be documented somewhere, thanks for the pointer !
73 Tim
G1BVI
Post by G1BVI » Sat Oct 28, 2017 7:38 am
Hi Guys and Gals
Just wondered if anyone had produced a drilling template for the Hammonf front panel.
Nick
G1BVI
Post by g0mjw » Sat Oct 28, 2017 7:53 am
Its in the WIKI document.
G1BVI
Post by G1BVI » Sat Oct 28, 2017 8:20 am
g0mjw wrote:Its in the WIKI document.
I had looked but did not come accross them.
Just delved in deeper and found them under notes on building the BATC MT.
Nick
