50 pin socket for minitoune wanted
G4HTZ
Post by G4HTZ » Tue Apr 04, 2017 2:59 pm
Anyone got a spare 50 pin socket for the minitoune PCB or can point me in right direction...farnell etc are out of stock
Digikey have them but postage costs very high if not spending £30 ...and don't need any other bits.
Part number is A3C-50DA-2DSA (71).
I've got the adaptor board for the serit ...just this missing part holding me up.
All costs covered
Essexsteve@icloud.com
Steve G3GHZ
Canewdon Essex JO01IO
5665 ATV FM
gm1mfn
Re: 50 pin socket for minitoune wanted
Post by gm1mfn » Tue Apr 04, 2017 8:19 pm
Is that a 2mm or 2.54mm pin spacing? If it's 2mm you could try this from CPC. They have no minimum order charge and, if you spend more than £5 online, postage is free.
Edited to add: OK, I've checked the Digikey spec and it is a 2mm part, so the Harwin one from CPC should fit.
Post by G4EWJ » Tue Apr 04, 2017 8:41 pm
I have 2 of the 24 pin connectors.
G4HTZ
Post by G4HTZ » Wed Apr 05, 2017 7:52 am
Thanks for replies
CPC had a minimum order level of 5 packs ...
Think I found a HARWIN socket on eBay now ...hopefully that will fit
Regards
Steve
Steve G3GHZ
5665 ATV FM
