MiniTiouner Kit MTK1 Instructions.
Re: MiniTiouner Kit MTK1 Instructions.
Post by g8gtz » Sat Apr 16, 2016 3:47 pm
Very nice Wouter :-)
But what's the ATV reciever with an CAT 5 port?
pa3weg
Post by pa3weg » Sat Apr 16, 2016 4:36 pm
Hi Noel,
That's a Grundig MicroSat STR-100 receiver for analog ATV
It has Low Threshold settings, and runs from 12V!
The CAT5 port is used for the infrared remote "eye"
I use that RX also to provide the LNB voltage (19Volt out of the 12V supply)
That way I do not need a step-up converter when running 12V portable!
All very much work in progress
EDIT: finished drilling the lid! All 128 holes...
ventilation is everything!
cashy666
Post by cashy666 » Tue Feb 14, 2017 9:02 pm
Hi all,
does anyone know where i can source the 220u 10v caps. I can't find anyone stocking them.
regards
G7MEG
g0uhy
Post by g0uhy » Tue Feb 14, 2017 9:46 pm
there are lots available from ebay. Try this link:http://www.ebay.co.uk/itm/Radial-Electr ... fTimxGfciQ
Not used them myself but seem reasonable price.
Malcolm
G0UHY
cashy666
Post by cashy666 » Wed Feb 15, 2017 1:22 am
HI malcolm,
thank you for your fast reply. The build specifies surface mount of a specific size, but it appears no one stocks then.
regards
G7MEG
g8vpg
Post by g8vpg » Wed Feb 15, 2017 9:18 am
Dave,
I used Farnell part no. 206-3065.
73 Shaun G8VPG.
g0uhy
Post by g0uhy » Wed Feb 15, 2017 10:15 am
the 220uF 10V caps are normal radial leaded. Are you confusing them with the 22uF SMD ones? (Farnell 2112754)
Malcolm
G0UHY
i2NDT
Post by i2NDT » Wed Feb 15, 2017 10:41 am
according to RS the manufacturer number of those 220uF 16 Vl is: GRM31CR61C226ME15L
I found them here: http://www.tme.eu/en/katalog/#search=GR ... order=DESC
I have already used TME and found them fast, reliable and sometimes cheaper than others...
i2NDT Claudio
i2NDT Claudio
Dalmine, Italia
cashy666
Post by cashy666 » Thu Feb 16, 2017 9:47 pm
Doh!!!!
sorry people...cant read my own hand writing..all sorted now...
thanks for your help and advice
regards
G7MEG
cashy666
Post by cashy666 » Wed Mar 01, 2017 2:09 am
Hi all,
Sorry if I'm being a bit of a pain but I'm really struggling with this build...been working on it for days..
all the components are fitted, led is lighting up.
checking for 5.4 - 5.6v I'm getting less than 1 volt at H1 / north west pad.
getting 9.5v at north west pad and at ZD2 D2 and 8.5 at R6..not 5.4v
any advice will be gratefully received.
regards
G7MEG
