Oscar 100 Live Tune software
Re: Oscar 100 Live Tune software
cool, i had a go but i could not get it to run under mono on my machine.
probably some missing libraries i have not installed!
A new version has been uploaded to the batc wiki which corrects for the frequency offset and the new DATV bandplan on OQ-100.
Versions older than 0.9b will no longer work correctly.
Download the new version here:
https://wiki.batc.org.uk/QO100_Live_Tune
Many thanks Rob for the Quick update, very much appreciated
cheers John G7JTT
cheers John G7JTT
And a big thanks from me, new version also running OK under Linux in mono.
Must admit I was looking for the start frequency in the bandplan.xml file. That may be a consideration to save you incase of future updates, although I would doubt if any more room left on the transponder.
Adrian
Adrian
G8UGD
https://qsl.net/g8ugd
Excellent.
I had thought about adding it to the bandplan settings and may do-so in a future version, but at the same time i would probably add the span too but that would need a bit more work.
Hopefully it will stay as-is for a while now
