MiniTiouner V2 - second TS NIM not detected
dl6rcg
Post by dl6rcg » Mon Feb 05, 2024 6:47 pm
Hello all,
I have extended my Minitiouner V2 with the circuit board for the second TS. I have successfully programmed the FT2232 module according to the instructions in the BATC Wiki. Unfortunately, I get the error message "NIM not detected, we quit" when I start the MiniTioune V1.0.1.0r beta software. When testing the second channel I get the following messages from "TestMyMiniTiouner_V1_3b":
DLL version: 3.2.16
we have found 2 device(s)
device 0:
device named: USB <-> NIM tuner A
For I2C, we will use this device
FT2232H I2C is open
Handle: 7305392
device 1:
device named: USB <-> NIM tuner B
For TS, we will use this device
FT2232H FIFO open for TS
Handle: 7276056
FT2232H FIFO closed for TS
USB driver version: 2.12.36
------ IP and UDP detection ------
IP n° 1 = 192.168.2.16
UDP address : 127.0.0.1 port : 1234 using IP interface : 127.0.0.1
****************** I2C controller INIT *******************
I2C controller INIT OK
OK MPSSE is empty
Init MPSSE I2C done!
NIM Test
Trying to get the Demodulator serial number
ERROR: impossible to read a correct value from Demod chip
END Test NIM
I soldered in the additional 10k resistor, but that didn't work either. I checked all the soldering points, connections, voltages, etc. Everything was ok.
Do any of you have a solution to my problem?
Greetings from Upper Franconia
Thomas - DL6RCG - JO60BA
g4eml
Re: MiniTiouner V2 - second TS NIM not detected
Post by g4eml » Mon Feb 05, 2024 10:30 pm
The second FTDI board is only for outputting the second TS. It doesn't have a connection to the I2C which talks to the tuner, only the first module can do that.
So the message at the end is correct, it can't read the demodulator chip.
I don't know if the minitioune software was ever able to make use of both TS.
I believe that OpenTuner can though.
PE1CHY
Post by PE1CHY » Tue Feb 06, 2024 10:12 am
Hi Thomas,
For the second output you need the OpenTuner software from ZR6TG. The original MiniTioune software can only handle the first channel. The second FTDI chip needs another programming, as described in the wiki. You need to connect both FTDI modules to the PC, I have used a good quality USB hub.
When you start the OpenTuner software it will see both channels :D ,
PE1CHY Rob
dl6rcg
Post by dl6rcg » Sun Feb 18, 2024 6:14 pm
Hi Colin and Rob,
thank you very much for your information and tips.
I was able to solve my problem quickly.
I also found out that the file for the FTDI in the BATC Wiki does not work. You have to use the file from ZR6TG. ZR6TG has a different device name for the FTDI. Only then will OpenTuner work perfectly.
Many thanks again and best regards
Thomas, DL6RCG
ON7TU
Post by ON7TU » Wed Apr 24, 2024 10:09 am
I have the following question:
Does the second FT2232 module also need the additional resistor between pin 19 and GND ? As I have some problems with the signal , from there my question. The NIM test is OK.
Basil
Post by Basil » Wed Apr 24, 2024 10:52 am
My second module also has the (same value as the first module) resistor. It runs 24 hours a day, 7 days a week and has worked flawlessly, save when I first built it and the Ebay sourced Chinese voltage converter played up occasionally and gave no output. I re-flowed the joints on it and zero issues from then on. It's been up, apart from occasional household power cuts, for well over 2 years. Same with my Pluto, LNB power, GPS frequency lock, et cetera. I work on the theory electrical stuff usually fails when turned on. Sorry Greta, I don't care :)
Good luck sorting it out,
Chris 2E0ILY
ON7TU
Post by ON7TU » Wed Apr 24, 2024 4:01 pm
OK , many thanks Chris for your reply.
I have not cheked yet the converter.
I will check further what's going on.
73's ON7TU - Lucien
