band switching
Posted: Fri Feb 20, 2026 12:39 pm
by moonbouncer
Hi all,
In my system the GPIO outputs for band switching are not the same for Langstone and Portsdown.
On 4m, 2m 70 cm and 23 the GPIO outputs on the pins GPIO 7, 32 and 35 are the same. But on the higher bands (13cm and up) the GPIO output on Portsdown is the same as on 23 cm (ie. 0,1,1), while on the Langstone transceiver they change on every higher band. E.g. on 13 cm the Langstone output is 1,0,0 and on Portsdown it is 0,1,1 (the same as on 23cm).
How can I solve this problem on Portsdown? I use the GPIO outputs for band switching.
73's de Ruud PA7RP
Re: band switching
Posted: Fri Feb 20, 2026 2:25 pm
by radiogareth
I'm fairy sure the Langstone band bits can be selected.....SET then scroll through to Tx and then RX band bits...
Re: band switching
Posted: Fri Feb 20, 2026 4:38 pm
You can more easily set them on the Langstone, so set them to be the same as the Portsdown. Problem solved.
Re: band switching
Posted: Sun Feb 22, 2026 11:01 am
by moonbouncer
That doesn't solve the problem. The problem is that on portsdown there is no difference on the status of gpio's 4, 12 and 19 for all bands above 1 Ghz.
So if I choose 23, 13 or 9 cm...the output on these GPIO's stays the same.
Re: band switching
Posted: Sun Feb 22, 2026 11:27 am
by Pa3fbx
Not on my system...
And also in Portsdown the GPIO selection can be changed in band settings...
Benno
Re: band switching
Posted: Sun Feb 22, 2026 1:25 pm
Perhaps not read this ?
https://wiki.batc.org.uk/Portsdown_4_GPIO_Connections -seems to be missing D3? There should be 4 band bits, not 3. Well actually 5 but who needs 5.
