Pluto problems on DATV tx with the Portsdown
m0lcr
Post by m0lcr » Tue Apr 15, 2025 8:43 pm
I have two plutos both exhibiting the same issue with the latest version of Portsdown.
Basically Band Viewer works fine, and signal generator works too, but when trying to tx video not a squeak no matter what settings are used.
Has anyone seen anything like this or recommend an approach to sorting it out.
Many thanks in advance
M0LCR
Re: Pluto problems on DATV tx with the Portsdown
Post by radiogareth » Wed Apr 16, 2025 6:36 am
Can you confirm that you are running the appropriate software in the Pluto.
https://wiki.batc.org.uk/Portsdown_4_Pluto
Has it ever worked or is this a new problem?
Other versions whilst not supported by PD4 do sometimes do 'something'.
There is a menu in PD4 to check Pluto firmware and report back what it finds.
Good luck
g6hfs
Post by g6hfs » Wed Apr 16, 2025 7:00 am
As it says on the tin, only this version works for Portsdown 4.
https://wiki.batc.org.uk/File:FIRM2101RC.zip
The latest Portsdown 4 works fine here with no problems.
m0lcr
Post by m0lcr » Fri Apr 18, 2025 4:43 pm
Thanks for the links to the wiki info on the Evariste firmware etc.
I’ll look into it when I visit the guys having the issue.
Many thanks
m0lcr
Post by m0lcr » Fri Apr 18, 2025 4:46 pm
Yes, checked the Portsdown version and it is updated to PD4
Many thanks for the suggestion.
