Re: how to add test card to Portsdown
Posted: Fri May 31, 2024 11:12 am
The process for adding custom test cards is described on this wiki page https://wiki.batc.org.uk/Portsdown_Test_Cards
You need to connect your Portsdown 4 to a LAN, and then use a Windows PC with a utility such as WinSCP to connect to the Portsdown. You can then add the files to the /home/pi/rpidatv/scripts/images folder. You do not need to delete the existing test cards.
