PID selection Minitiouner via Portsdown 2020
PA3GUO
Post by PA3GUO » Fri May 03, 2024 6:22 pm
Usecase:
Minituner hardware connected via USB to a Portsdown 2020 (3.5inch). Control via the touchscreen.
How can I select another PID from a received station?
(Our local repeater pi6ehv broadcasts multiple streams in its 5000ks signal, minituner now selects the default / first discovered PID)
Henk
Re: PID selection Minitiouner via Portsdown 2020
Post by G8GKQ » Fri May 03, 2024 7:18 pm
Hi Henk
That feature is not available on the Portsdown 2020. It is available on the Portsdown 4 (Receive menu, Config, TS Video Channel).
You could manually modify the lmvlcff.sh script to play a specific channel, but it would be quite a lot of work to add the option to select it from the touchscreen.
Sadly, I do not have the spare time to make major feature updates to the Portsdown 2020 at the moment.
PA3GUO
Post by PA3GUO » Fri May 03, 2024 9:02 pm
Thanks for the fast reply Dave.
Good to know its not available, so I dont keep on searching for a non-existing menu option.
I guess this means for now I will skip this use-case.
No worry!
Best regards
Henk PA3GUO
