7" Touchscreen won't Invert
M1ASR
Post by M1ASR » Tue Mar 12, 2024 3:28 pm
The ethernet port on my rpi stopped worked, so replaced the rpi with a freshly built Buster-lite SD Card. The installation works as expected. However, the touchscreen display won't invert. When pressed, the "invert touchscreen" doesn't change anything. I expected it to say reboot, but screen just flashes once.
I would add, it's just the rpi that has been replaced, not the touchscreen. To check, I've just rebuilt another PD4 with a new rpi and new touchscreen with same result.
Is there a work around for this, as relying on web control at the moment.
All other features appear to work, including invert "pi camera".
I have another PD4, which was configured about 3 months ago and that works fine.
Thank you in advance.
Graham M1ASR
Re: 7" Touchscreen won't Invert
Post by G8GKQ » Tue Mar 12, 2024 3:41 pm
Sorry Graham
I thought that I had fixed that. I'll take a look at it later this week.
M1ASR
Post by M1ASR » Tue Mar 12, 2024 3:56 pm
I've commented out the "lcd rotate=2" line in the config file and that's fixed it for now.
Many thanks for the quick response.
Graham M1ASR
Post by G8GKQ » Wed Mar 13, 2024 8:20 pm
i Graham
I have just fixed this in the latest release. No point in changing your system - the button simply does what you did manually!
Thanks for reporting the problem.
M1ASR
Post by M1ASR » Thu Mar 14, 2024 12:56 am
Thanks for sorting, everything working well here. I’m setting up for Q100 at the moment, having moved QTH.
