Portsdown 4 Update for new BATC EasyCap
Post by G8GKQ » Tue Oct 17, 2023 10:04 am
I have just released an update to the Portsdown 4 (202310110) that adds limited support for the MS2106 EasyCap composite video capture device that is available from the BATC Shop https://batc.org.uk/shop/video-capture- ... portsdown/.
The update introduces the capability for Lime and Pluto H264 DVB-S/S2 transmissions and streaming using this EasyCap (and the old one). DVB-T and MPEG-2 are not yet supported. Full details can be found here: https://wiki.batc.org.uk/Portsdown_hard ... ure_Device
I have also added some support (Lime DVB-S/S2 H264 transmissions) for the Logitech Brio 4K Camera.
Please post details of any problems with this new release here.
g6hfs
Re: Portsdown 4 Update for new BATC EasyCap
Post by g6hfs » Wed Oct 18, 2023 6:39 pm
I can report update all working here.
keng8vdp
Post by keng8vdp » Wed Jan 03, 2024 8:01 pm
I have both types of "easycaps" as mentioned above both checked in Portsdown via menu 2 /
File menu/ list usb.
The Fushicai shows as easycap .
The other one shows as 534d:0021
Problem: the 534d:0021 displays video ok via the monitor function. All good
When I then switch to menu 1 & tx I only transmit a Green Screen.
If I reboot it's the same fine on monitor function but no video on TX. Checked all connections etc.
534d:0021 displays/ captures fine on a pc as does the genuine Fushicai.
My Portsdown is fully up to date
Any ideas ?
Ken
Post by G8GKQ » Sat Jan 13, 2024 11:22 am
Hi Ken
To fault find this, I need to know all the settings that you are using. Please could you provide a photo of Menu 1 when you are trying to transmit?
