Win32diskimager and Win 11
M1ASR
Post by M1ASR » Mon May 22, 2023 7:41 pm
Dear all, I needed to build a new Portsdown 2020 SD card and Win32diskimager wouldn’t work. I used the Raspberry Pi imager in the end, which worked ok. Anyone found a version that works with Windows 11. Thank you in advance. Graham M1ASR
Basil
Re: Win32diskimager and Win 11
Post by Basil » Mon May 22, 2023 7:52 pm
I think BalenaEtcher is supposed to be Windows 11 compatible, but I don't run 11 so haven't tried it.
https://etcher.balena.io/
Best regards,
It was a lot more fun being 20 in the 70's than being 70 in the 20's
M1ASR
Post by M1ASR » Tue May 23, 2023 10:14 am
Thank you for your reply, I have now tried balenaetcher and can confirm that it works fine on Windows 11.
Regards
73, Graham M1ASR
Post by M0DTS » Tue May 23, 2023 10:57 am
If you like a simple exe with no installer then Rufus has worked well for me.
https://rufus.ie/en/
M1ASR
Post by M1ASR » Tue May 23, 2023 1:05 pm
Thanks Rob, will take a look,
Regards
73, Graham M1ASR
g6hfs
Post by g6hfs » Tue May 23, 2023 9:59 pm
I have always used Raspberry Pi imager never had a problem
G8KOE
Post by G8KOE » Wed May 24, 2023 6:19 am
I use BalenaEtcher with Windows 11.
Simple to use and just works.
Martin
G8KOE
M1ASR
Post by M1ASR » Wed May 24, 2023 8:05 am
Yes, Balena Etcher and rpi imager are both fine. Just written a Portsdown 2020 SD Card with etcher and rpi imager in Windows 11. Thank you for all the replies.
Regards
73, Graham M1ASR
