IPTS in no longer working on Porstdown 2020
Post by G3GJA » Tue Mar 28, 2023 10:11 pm
Two Portsdown 2020 systems have been tried with IPTS in on transmit and IPTS monitor.
Neither work; has the feature been disabled? The Wiki suggests that it should still work.
Clive
Re: IPTS in no longer working on Porstdown 2020
Post by G8GKQ » Wed Mar 29, 2023 7:08 pm
Hi Clive
It is still working - I've just tested it on both a Portsdown 2020 with a 3.5 inch screen and one with a 7 inch screen (fed from a Portsdown 4).
The IPTS monitor uses OMXPlayer (not VLC, which is used in the Portsdown 4), and is very fussy. The capabilities:
  • It will display an MPEG-2 TS, with or without an audio channel
  • It will display an H264 TS, but only if there is an audio channel. Note that Test Card transmitted from Portsdown does not have an audio channel.
  • It will not display H264 if encoded by an SR Systems encoder (I have yet to find what the issue is with the SR Systems encoders)
  • It will not display H265
IPTS Transmit is also fussy:
  • It will only transmit MPEG-2 if there is an audio channel
  • It will only transmit H264 if there is an audio channel
  • I'm unable to test SR Systems encoder or H265, but they might work
Hope that helps
Post by G3GJA » Thu Mar 30, 2023 11:16 pm
Hi Dave
Thanks for the info. I've now succeeded with some excellent results at symbol rates from 500 to 2000kS/s using an H264 stream generated from FreeStreamCoder v2.79 and OBS Studio. 250 & 333kS/s work too, with reasonable results.
Using IPTS with the Portsdown 2020 is not mentioned in the Wiki section on 'Tested modes of operation using the Filter-Modulator board' so I've added what I found to work.
Clive
Post by G8GKQ » Fri Mar 31, 2023 9:06 am
Hi Clive
Pleased that it is working for you.
And thanks for updating the Wiki - I wish more people would!
