PiCam via HDMI cable problem solved
Posted: Thu Dec 08, 2022 4:01 pm
by g3yjr
My PiCam works with PD4 directly via a ribbon cable.
In order to use the PiCam via a cable, I bought a couple of Petit Studio adapters from Pimoroni and modified them for screen ground and pin 13.
I used an HDMI cable with an adapter fitted on each end. I can see 3.3V on the remote (PiCam end) adapter, so I seem to have the ribbons the right way up in their connectors, but the PiCam doesn't work via the HDMI cable.
I tried checking continuity ribbon to ribbon via the HDMI cable and all pins looked OK except pin 14. Might this be my problem?
73 Graham G3YJR
Re: PiCam via HDMI cable problem
Posted: Thu Dec 08, 2022 4:27 pm
Graham
That will be an unsuitable HDMI Cable. Pin 14 carries the configuration data commands for the camera. See the table on this page https://wiki.batc.org.uk/CSI-2_to_HDMI
Try another cable - even if you have to borrow it from the family TV!
Posted: Thu Dec 08, 2022 4:58 pm
by radiogareth
That worked for me too, not all cables are created equal, ironically it was a cheap one that did work for me.
Good luck.
Posted: Fri Dec 09, 2022 8:51 pm
by g3yjr
I probably have another cable somewhere. I have previously used the current cable for actual HDMI from RasPi to a monitor.
I'll have a search.
73 Graham
Posted: Mon Jan 02, 2023 10:26 pm
by g3yjr
I bought a new HDMI cable from Pimoroni & now I get an image on PD4's PiCam Monitor function.
The cable which works is marked 30V VW-1 HTS
There is some more detail on how I hooked up the HQ PiCam using an HDMI cable here:
https://g3yjr.wordpress.com/2023/01/10/ ... ortsdown4/
Thanks Dave & Gareth.
73 Graham
