Portsdown - Now Safe to Update Again!
Posted: Tue Jun 21, 2022 11:17 am
Hi All
A recent change to VLC has broken the receiever in the Portsdown software. This is totally outside my control and really frustrating for me. I'm working on a fix, but in the meantime, if you want to retain receiver functionality, don't do any Portsdown updates (or Langstone updates from Portsdown).
Dave G8GKQ
Re: Portsdown - Don't Update at the Moment
Posted: Tue Jun 21, 2022 3:03 pm
If you have updated your Portsdown (or Ryde) and it does not now receive anything using VLC, entering the code below will fix it.
The first segment (which rolls back to the previous version of VLC) is a series of lines that the RPi reads as one line due to the \ markers at the end of each visual line:
sudo apt-get --allow-downgrades -y install vlc=3.0.12-0+deb10u1+rpt3 \
libvlc-bin=3.0.12-0+deb10u1+rpt3 \
libvlc5=3.0.12-0+deb10u1+rpt3 \
libvlccore9=3.0.12-0+deb10u1+rpt3 \
vlc-data=3.0.12-0+deb10u1+rpt3 \
vlc-plugin-base=3.0.12-0+deb10u1+rpt3 \
vlc-plugin-qt=3.0.12-0+deb10u1+rpt3 \
vlc-plugin-video-output=3.0.12-0+deb10u1+rpt3 \
vlc-l10n=3.0.12-0+deb10u1+rpt3 \
vlc-plugin-notify=3.0.12-0+deb10u1+rpt3 \
vlc-plugin-samba=3.0.12-0+deb10u1+rpt3 \
vlc-plugin-skins2=3.0.12-0+deb10u1+rpt3 \
vlc-plugin-video-splitter=3.0.12-0+deb10u1+rpt3 \
vlc-plugin-visualization=3.0.12-0+deb10u1+rpt3
The second segment is 15 individual commands to prevent the problem recurring:
sudo apt-mark hold vlc
sudo apt-mark hold libvlc-bin
sudo apt-mark hold libvlc5
sudo apt-mark hold libvlccore9
sudo apt-mark hold vlc-bin
sudo apt-mark hold vlc-data
sudo apt-mark hold vlc-plugin-base
sudo apt-mark hold vlc-plugin-qt
sudo apt-mark hold vlc-plugin-video-output
sudo apt-mark hold vlc-l10n
sudo apt-mark hold vlc-plugin-notify
sudo apt-mark hold vlc-plugin-samba
sudo apt-mark hold vlc-plugin-skins2
sudo apt-mark hold vlc-plugin-video-splitter
sudo apt-mark hold vlc-plugin-visualization
I will build these into the build and update scripts in the next few days.
Posted: Tue Jun 21, 2022 3:26 pm
by G8KOE
Thanks Dave Now Working!
73's
Martin
G8KOE
Posted: Wed Jun 22, 2022 8:20 pm
I have just released an update to the Portsdown 4 that cures the VLC problem, so new builds and updates should now work.
The equivalent work for Portsdown 2020 and Ryde will have to wait until Monday. I've run out of time!
Posted: Thu Jun 23, 2022 1:05 pm
by IZ7PDX
Congratulations, always a great job!
Hope to have some time to work on it in the next few days ....
Posted: Mon Jun 27, 2022 8:47 pm
I have just published an update to the Portsdown 2020 that corrects this fault, so it is now safe to update both the Portsdown 4 and the Portsdown 2020.
Re: Portsdown - Now Safe to Update Again!
Posted: Tue Jun 28, 2022 5:19 pm
by G8XPZ
Hi Dave
Thanks for your excellent work on this. Portsdown 4 now fully functioning.
De Steve G8XPZ
