Portsdown 4 and MiniTiouner V2
G8KOE
Post by G8KOE » Wed Jun 08, 2022 9:16 am
If I fit the RT5047 current limit PCB is this controllable from Portsdown 4 software?
0v 13v or 18v
Martin
G8KOE
G8KOE
Re: Portsdown 4 and MiniTiouner V2
Post by G8KOE » Wed Jun 08, 2022 5:19 pm
Input Port and Voltage Selection
The tuner input port (A = upper, B = lower) can be selected from the Configuration Menu. This setting is stored independently for QO-100 and Terrrestrial.
If the correct hardware is fitted to your tuner, the LNB Voltage can also be set from the Configuration Menu (agauin independently between QO-100 and terrestrial).
I've found the answer to my own question.
Martin
G8KOE
