Easy cap
Posted: Thu May 05, 2022 6:04 pm
by Patrick
hello.
i work with Portsdown 2020 and I am looking to use my CVBS cameras with Easy Cap.
Unfortunately, the one I own does not work...
Which model to use and or buy?
73's
Patrick / F6exx
Re: Easy cap
Posted: Thu May 05, 2022 7:21 pm
Hi Patrick
The only Easycap that works properly is the Fushicai USBTV007. Others look the same but do not work.
More details here: https://wiki.batc.org.uk/Fushicai_USBTV007
The correct ones are very difficult to obtain.
Re: Easy cap
Posted: Fri May 06, 2022 12:42 pm
by Patrick
Bonjour.
Merci Dave .
I wait for this Easycap …
Patrick
Re: Easy cap
Posted: Sun May 08, 2022 8:23 am
by g8lce
I have found that this HDMI to USB device works in place of the original Easycap. It does not do sound but that can now be sorted with a usb audio device. I don't know if this device will work for you as I bought mine some time ago and they may use different chips. It would be a gamble to try one.
https://www.ebay.co.uk/itm/203919251662 ... SwcGNiVvnA
If you do find it works let others know...
Re: Easy cap
Posted: Sun May 08, 2022 9:03 am
by radiogareth
I use these to feed various sources into my PC+OBS. Did it just plug and play with a Portsdown??
Sounds too good to be true, but I and at least one (Justin G8YTZ) other wondered just this a few days ago!
Re: Easy cap
Posted: Sun May 08, 2022 9:21 am
by g8lce
I took the EasyCap out and put the HDMI to USB in. Lucky or what?
Now I am trying to find the mic level adjustment for the Portsdown as it is too high. (see GB3NQ stream ) Still a problem with 16 by 9 but that was the same with EasyCap
Re: Easy cap
Posted: Sun May 08, 2022 11:56 am
by g8lce
I have just tried another one that is a different source and it works as well. Don't expect audio though...
Re: Easy cap
Posted: Sun May 08, 2022 2:29 pm
by radiogareth
Just tried mine (https://www.ebay.co.uk/itm/133924177499) and that too works. I have audio, but its from the USB dongle source when left on Auto.
Great find :-)
