Portsdown 4 Update
Posted: Thu Mar 31, 2022 9:53 am
As announced in CQ-TV 275, I have recently issued an update (202203071) to the Portsdown 4 with the following enhancements:
- Local web browser access to the touchscreen controls
- Full support for the DFRobot 5 inch touch screen
- Integration of Langstone V2, with the ability to use the LimeSDR instead of the Pluto
Full details are in CQ-TV. Please report any bugs or problems here.
Re: Portsdown 4 Update
Posted: Thu Mar 31, 2022 8:51 pm
by VK3IE
Web browser looks and works well.
When viewing snaps maybe an exit or back to listing or a next button ?
I read about using back button in web browser in the doc's CQ-TV 275.
Posted: Tue Apr 05, 2022 9:24 am
by G3VZV
Love the web browser!
Thanks to Dave and Phil..
Graham G3VZV
Posted: Tue Apr 05, 2022 9:45 am
by G3GJA
I like the use of a virtual drive in RAM to store the screen snapshots, preventing wear on the SD card and improving the speed.
Clever!
Clive
Posted: Thu Apr 21, 2022 7:18 pm
by g3yjr
The combination of the web interface and VLC on my PC worked really well over Ethernet.
I watched the BATC net on the PC, PD4 doing the business!
The web access is a neat feature, thank you.
73 Graham
Posted: Tue May 03, 2022 10:45 am
by PE1NCH
Na het updaten kreeg ik de volgende error.
Error Undefined parameter p3label in file:
/home/pl/rpidatv/scripts/portdown_presets.txt
Restore manually or by factory reset
Touch Screen to Continu
Hoe kan ik dit verhelpen
Posted: Tue May 03, 2022 1:29 pm
This means that at some time you have deleted the label for Preset 3.
Two options:
- Perform a factory reset. Log in to the command line, type menu, and use the menu option for a factory reset. Or:
- Edit the presets file to correct it:
nano /home/pl/rpidatv/scripts/portdown_presets.txt
Use the arrow keys to go down to the p3label line and set it:
Then press ctrl-x, y, enter.
Then type
and it should run OK.
There is an example portdown_presets.txt file here
https://github.com/davecrump/portsdown4 ... s.txt#L217
Posted: Fri May 06, 2022 4:17 pm
by PE1NCH
Hallo Dave het is me gelukt met fabrieks instelling
Thanks Dave
